Calendar Integration Configuration
Rustee12_ca
Is there a way to outright disable calendar integration during the Jabber client installation?  And allow the user to enable it only if they wish?  Using version 10.5 of the Jabber client.
Jaime Valencia
No, there is no way to disable this feature, you would need to submit a PER for this to be considered.
java
if this helps, please rate
On 10.5.1 For Windows it now appears via options that you can select to not have any integration with any calendar or select Notes, Google or Outlook.
