Calendar Integration problem with Cisco Jabber
I have presence cluster on version 9.1.1.10000-8. The cluster is integrated with CUCM cluster (5 servers) on version 9.1.1.21017-2 and with Exchange 2010.
At first everything worked fine but suddenly the calendar intgration stopped work.
On the jabber client I can see the calendar meetings but the status of the jabber clint doesnt change to "In a meeting".
If I try to disable the calendar integration and then re enable the status of the client is being changed but then ' when the meeting is over it doesnt change back to "available".
I double chacked all the configurations on the presence servers and on the exchange server and everything is look ok.
can somebody help?
Liran.
Hi Liran,
this does not seem to be a known issue. We would need a PRT to analyze this issue - so I can strongly suggest you to open a TAC case.
Nebojsa
Hi Nebojsa,
Thanks for your replay.
I think I will open a new TAC.
Liran.
Still nothing new about this case.
I will update you ASAP.
Liran.
606
