Can Jabber works without a phone ?
Has anybody know?
Is it possible to setup Jabber without a phone?
I mean create only Jabber profile at Cisco Unity and skip the phone profile.
Thank you,
Sergey
Re: Can Jabber works without a phone ?
Which Jabber are you asking about???????
java
if this helps, please rate
www.cisco.com/go/pdi
I mean Cisco Jabber - application for instant messaging.
Actually, I already tested it and can say that YES it works without the phone, that is really cool.
Now, I can create only Jaber profile on Cisco Unity and make a calls using Jabber Client only.
Sergey
297
