Can not sign in to Cisco Jabber
Hi all,
I am using Cisco Jabber version 9.0.2 (in Windows 7). Connection Settings :
      Server type : Cisco WebEx
       Login server : Use the default server
After I enter my account and sign in, Cisco Jabber notifies "Invalid username and password". But I still connect properly with this account by using Cisco Webex connect.
Any body know why?
Thuc
Everyone's tags (4)
Do you still get the issue if you specify the server name instead of the using the default?
Hi Coflaher,
Could you give me the server name ?
Thuc
Hi Nguyen,
I have no way of checking the webex server name you need.
You can try and open a support case with webex and they should be able to help.
- Colin
Hi Nguyen,
Jabber for windows requires to enter username with domain e.g. if your username is "abc" and domain is "example.com", then you should enter "abc@domain.com" as username. If you are entering username in this format and login is failing then please open support case as Colin suggested.
Maqsood
Thank you everybody. I will try to open a TAC case
Thuc
1266
