04-09-2014 01:35 AM - edited 03-17-2019 04:05 PM
Hi together,
we have csf devices configured for jabber for windows, For the case that the user isn't logged in the Jabber Client, we have configured call forward unregistered (CFUR). This works as expected, but when we add additional TCT device (jabber for iPhone) with the same number, CFUR doesn't work anymore because the the CUCM signal busy now (if both Jabbers offline). Thats the wrong behavior from my point of view.
What can we do to avoid this, any suggestion are welcome.
04-12-2014 12:59 PM
you have identified this correct; in order for jabber for iPhone users to get the CFUR to work appropriately you will need to configure Mobile Connect; until then the behavior you reported seems working as designed. Please refer to the following link to learn more about how to configure mobile connect;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/iPhone/9_1/JABI_BK_JEE78137_00_jabber-voice-iphone-admin-guide-9-1-6/JABI_BK_JEE78137_00_jabber-voice-iphone-admin-guide-9-1-6_chapter_011.html#CJAB_TP_SADF0101_00
Please rate it this helps.
05-07-2014 05:50 AM
Hi together, thanks for your answers. Unfortunatelly this hints doesn't solve the problem, so I will open a TAC case.
12-02-2014 09:53 AM
What did TAC Say
12-03-2014 02:34 AM
TAC sad "works as designed". So no fixes available, but a colleague reported that it works in 10.5.1 as expected ;-)
08-04-2015 02:28 PM
I am at 10.5.2 and I still have the same so the issue remains the same :(
The behaviour is documented on the following bug
CSCus09008
