Community Member
Cisco Interaction manager (Web Chat) issue
Dear All
We are facing an error in CIM 4.4.1 that only one of the agents cannot handle more than two chats. We have set the value of maximum chat per agent to Four.
we have configured only one department and one queue. Rest of agents are getting chats normally. Anyone experienced and got its fix.
Community Member
Hi Muhammad,I'm planning to
Hi Muhammad,
I'm planning to install CIM and I'm still not able to figure out how to integrate the Chat module in the portal.
Can you kindly guide me to a helpful document?
Thank you in advance.
Lara
Community Member
Hi laranoueirI did not try
Hi laranoueir
I did not try integration however i saw the procedure of integration (CIM with UCCE) in the installation guide of CIM. You can check that guide, if do not find it in your guide let me know i will share guide with you.
Community Member
Hi Muhammad,What I meant by
Hi Muhammad,
What I meant by how to integrate the chat module in the portal was not the integration with UCCE. Actually I need to know how to link the 'chat with an agent' button in the website with the CIM system.
thank you in advance.
Lara
Community Member
Ah got you. Login to Admin
Ah got you.
Login to Admin page. expand department>Service>Chat>Entry points>Default Entry point
on this PAN you will see an icon of Internet Explorer. that is basically HTML code. Copy that code to website for the integration.
Free free if you still have any query.
Community Member
Thank you Muhammad.I will try
Thank you Muhammad.
I will try to install and configure cim and will let you know if I have any issue.
Best Regards,
Lara
Community Member
Hi Muhammad,If your CIM
Hi Muhammad,
If your CIM deployment is integrated with ICM, try to add a LAA selection node to your script (specifying the SkillGroup in the Consider if text field).
Let me know if this works.
Best regards,
Vinicius Machezini
Community Member
Hi MarcheziniThanks for your
Hi Marchezini
Thanks for your reply. But we are not using CIM integrated.
Regards:
Muhammad Ahmad
119
