CISCO Jabber 8.6.2 and CME 8.6
I want to use Cisco Jabber 8.6.2 with Call manager Express 8.6
I configured the IPhone on CME and is working ok on local wireless LAN,
When I’m using the VPN I can place call's inside the network but I can't use on outside line. I have no sound.
Also if I place a call and the I end the call, the called phone rings and is not stopping. So I think is a call disconnect problem.
Bellow is a part of the configuration.
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
call start slow
sip
session transport tcp
registrar server
voice class codec 1
codec preference 1 g729r8
voice class custom-cptone romania
dualtone busy
frequency 450
cadence 170 170
dualtone disconnect
frequency 450
cadence 170 170
voice register global
mode cme
source-address 10.12.4.252 port 5060
max-dn 10
max-pool 10
authenticate register
hold-alert
tftp-path flash:
create profile sync 0000545624458818
voice register dn 1
number 5146
call-forward b2bua all 5108
call-forward b2bua busy 5160
call-forward b2bua noan 5160 timeout 18
name Ioan Stanciu
shared-line
label Ioan
voice register pool 10
registration-timer max 720 min 660
id mac 68A8.6D91.3FE0
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
username 5146 password 5146
voice-port 0/0/0
supervisory disconnect dualtone mid-call
supervisory custom-cptone romania
no battery-reversal
timeouts call-disconnect 2
timeouts wait-release 2
connection plar opx immediate 5150
caller-id enable
voice-port 0/0/1
no battery-reversal
caller-id enable
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec g722-64
maximum sessions 1
associate application SCCP
dial-peer voice 2 pots
preference 2
destination-pattern 9T
incoming called-number .
direct-inward-dial
port 0/0/1
telephony-service
video
maximum bit-rate 256
no auto-reg-ephone
em logout 0:0 0:0 0:0
max-ephones 25
max-dn 120
ip source-address 10.12.4.252 port 2000
max-redirect 7
auto assign 1 to 8
service phone videoCapability 1
service phone paramEdibility 1
no service directed-pickup
timeouts interdigit 6
timeouts ringing 15
Any idea what can be the problem ?
Is the connect over 3G enabled on your iPhone? Try this.
Btw, what have you put as device ID on your iPhone? the MAC address?
To my knowledge, the device ID is TCTXXX for CUCM, there is no info related on how to add it for CME 8.6
Dear All
is there any update about cisco iphone jabber with CME 8.6.
What we have to put on device id on iphone?
also , is license is mandatory to use, for lab testing?
Re: CISCO Jabber 8.6.2 and CME 8.6
Device ID is SEPXXXXXXXXXXXX on CME
TFTP Server is your CME router
2234
