cisco jabber 9x - users photot not available .
Hello all ,
i have cisco presence 9.1 with jabber 9x , on jabber windows i can see the photo of LDAP users but i cn not see the photo on jabber Iphone. can any one one help me to fix it .
Bronze
You will need to elaborate
You will need to elaborate your query a little bit. What i would need to know is:
-> Whether the photo is saved as a thumbnail photo ?
-> or, do we access the photo from a URL location ?
-> What version of jabber for iPhone are you referring to ?
If you are referring to jabber for iPhone version 9.6; you would like to refer to the following link to understand how to reconfigure the jabber-config.xml to get the contact photo to work for jabber for iPhone 9.6;
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/iPhone_iPad/JABI_BK_I30346C6_00_installation-and-configuration-guide-for-iOS/JABI_BK_I30346C6_00_installation-and-configuration-guide-for-iOS_chapter_0110.html
hi!I have the same problem ,
hi!
I have the same problem , in jabber 9.6 for windows  , works fine without any configuration in
jabber-config-xml.
now , i will try to configure the photo parameters in the xml file.
185
