02-19-2014 06:17 PM - edited 03-17-2019 03:57 PM
I am trying to install Jabber Client 9.6(1) with this installation command
msiexec.exe /i CiscoJabberSetup.msi /quiet CLEAR=1 AUTHENTICATOR=CUP CUP_ADDRESS=1.2.3.4
but it didn't set account type as cisco IM & Presence instead it stays in Automatic
Is there any correct property to set it to Cisco IM & Presence as account type. Thanks for your help.
02-20-2014 09:01 PM
That is the correct, documented structure of the command so I'm unsure why it didn't work. Have you considered doing DNS SRV records instead? It's both the recommended and far easier way to get this done.
If DNS really isn't an option for you, you could also consider creating an MST file using ORCA and using that instead of manual CLI switches.
If CLI switches are really your only option and no one has a better idea, try an older release (e.g. 9.2.6) just to see if it ever works. Depending on the outcome, it may be time for a TAC case.
Please remember to rate helpful responses and identify helpful or correct answers.
03-04-2014 04:58 AM
we have the same problem with CLI switches. Have you solved the problem?
regards
joerg
