09-26-2013 03:34 AM - edited 03-17-2019 03:33 PM
Hi.
we are using cisco Jabber 9.2.3 for windows on CUCM 9.X
we have observed a very strange issue that after ending call from Cisco Jabber, the Jabber application gets disconnected
meance we again need to loging to make new call..
Please suggest ..
09-27-2013 01:46 PM
You can get a problem report from application by clicking on help>create a problem report to look for errors.
Are you using softphone control(calling from PC) or deskphone?(controling your IP phone with Jabber)
9.2.5 is out, can you test with the new version?
09-28-2013 07:42 AM
I recall seeing a bug for similar issue, you may want to scan the bug toolkit.
HTH,
Chris
