Cisco Jabber in Samsung Galaxy Note 3 using VPN
I cant not register my cisco jabber to CUCM 9.1 with Samsung Galaxy Note 3 using built-in VPN neither cisco anyconnect.
Does anyone have any workaround or solution.
Use the "send problem report"
Use the "send problem report" link from the error message and enter your own email address, then examine the logs that it sends or post them here.
Hello geguy  I open a ticket
Hello geguy
I open a ticket with TAC and send them the problem report from jabber, but the answer was "Device Not Supported" and recomend that follow this community for any workaround.
They simple say NOT SOLUTION FOR THIS DEVICE. so I hope find any workaround here.
Anyway, thanks for the advice.
Sure, but send the problem
Sure, but send the problem report to YOURSELF by entering your own email address, then examine the logs, or post them here.
793
