Cisco Jabber installation hangs
nmoore1978
I'm attempting to install Cisco Jabber on a Windows 7 SP1 32-bit virtual machine.  I'm prepping the machine to be cloned using VMware View Agent v5.3.0.1427931.  This happens with both Jabber v9.6.1 and v9.7.0.
The installation starts normally, starts copying files, places the desktop shortcut and then a Windows Installer box opens with "Preparing to install...".  And then nothing else happens.  I can use task manager to end the installation.
Any ideas?
Nick
5 Replies 5
nmoore1978
After about 20 minutes I get the following message:
Windows Installer
Install server not responding
Did you figure this out? I am having the same problem.
Nope.  No resolution yet.  Tried opening a ticket with support.  Still nothing.
This is very frustrating.
fpiccinin
Hi all, we're experiencing the same issue while deploying cisco jabber 9.6.1
It seems related with this dll registration: CUCMessenger.dll
Trying to manually regsiter it lunching this command:
regsvr32 "C:\Programmi\Cisco Systems\Cisco Jabber\CUCMessenger.dll
everything seems to go fine.
Any news from the tac support?
thanks BR
Tapan Dutt
Hi Nick
Please can import the event viewer logs from the Win Machine and share it here
Tapan
