Cisco Jabber integrate Exchange Unified Messaging for Voicemail
The Cisco Jabber works great with Unity connection for voicemail, our company use Exchange 2010 UM for voicemail, is there anyway we can integrate Cisco Jabber with Exchange UM to check voicemail.
Thanks much
VIP Super Bronze
Nope. You'll need to use Outlook.
Please remember to rate helpful responses and identify helpful or correct answers.
Is it possible to integrade Jabber with Exchange using Unity Connnection configured to use and Exchange Messanging ?
Jabber does work with CUC (with or without UM) so you can get the VM notifications and review them
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
1541
