Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Cisco Jabber Issue
In Jabber 11.0.0 I inadvertently deleted the customer status options from the status drop down menu.  I can't figure out how to get those back.  I use them frequently.  Any help getting them back in the menu is much appreciated! -Ricky
1 REPLY
I don't think you can get
I don't think you can get your custom status back, you'd need to configure them again.
java
if this helps, please rate
www.cisco.com/go/pdi
71
