Cisco Jabber MRA /Pronlem with phone services
I can login in jabber via MRA but i dont have phone services(In the corporate networks it is works fine)
any advice
thanks
Everyone's tags (1)
Hello,I has the same problem
I has the same problem with phone service from external network. In Internal everything is OK, all DNS SRV Record work well. When I connect from Internet, IM and Presence login successful, but phone service not work.
Please advice, I has attached screen capture about this errors.
Trung.
hI trungndc11 , I fix it with
I fix it with this :
"Endpoints may not be able to register to Unified CM if there is also a SIP trunk configured between Unified CM and Expressway-C. If a SIP trunk is configured, you must ensure that it uses a different listening port on Unified CM from that used for SIP line registrations to Unified CM."
 now i can register the phone  but i am not  listening anything
Hi C.carrion,I don't have SIP
Hi C.carrion,
I don't have SIP Trunking between Expressway-C and CUCM, but phone service cannot register.
Any ideas for this case ?
Trung.
Hi everyone, Currently I have
Hi everyone,
Currently I have same problem with this case,
IM & Presence work fine from internet (public network) but phone service is "Not Connected",
But If from internal network those services (IM, Presence, and phone service) just work fine.
Did you solve this problem?
please advise :)
Thanks.
Ovindo
Hi Ovindo, A lot of factors
Hi Ovindo,
A lot of factors can contribute to this specific problem. It all depends on how you set things up in your deployment. Some of them are related to the certificates.
To start of, login to the vcs control/exp-c's event logs to get a birds eye view as to what's happening. In the above scenario, it was due to TLS failure.
What do you see in the event logs?
Hi Chirag, In my deployment,I
Hi Chirag,
In my deployment,
I'm using dual NIC in my Exp-E (1st local & 2nd direct public).
Attached screen capture from both my Exp-C and Exp-E.
Please advise.
Ovindo
Hi Ovindo, _collab-edge DNS
Hi Ovindo,
_collab-edge DNS SRV record points to Expressway's FQDN; which is edge.kayreach.com
But, the ports (8443, 5061 and 5222) to that Expressway's FQDN is not open.
C:\>telnet edge.kayreach.com 8443
Connecting To edge.kayreach.com...Could not open connection to the host, on port 8443: Connect failed
C:\>telnet edge.kayreach.com 5222
Connecting To edge.kayreach.com...Could not open connection to the host, on port 5222: Connect failed
C:\>telnet edge.kayreach.com 5061
Connecting To edge.kayreach.com...Could not open connection to the host, on port 5061: Connect failed
Open these ports on firewall as mentioned in the VCS MRA Deployment Guide:
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-5/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-5.pdf > Page 36 of 50
thanks, i had the same "phone
thanks, i had the same "phone services are not available" problem for Jabber from outside through Expressway deployment.
the issue was that port 5061 (SIP signalling) was blocked, and once allowed the phone services worked just fine.
the tricky thing was that port 5061 was already allowed on the customer firewall to the Expressway E IP address, but after troubleshooting we discovered that traffic to that port was not reaching our firewall at all, then after contacting the ISP we found that it was blocked from the ISP side.
these websites can be used to check if the port is opened of not:
http://www.portcheckers.com/
http://www.yougetsignal.com/tools/open-ports/
http://www.networkappers.com/tools/open-port-checker#.VoJjIcZ97Dc
http://ping.eu/port-chk/
That was exactly the issue
That was exactly the issue also in our case.
Regards\Mohamad
Please provide the Jabber PRT
Please provide the Jabber PRT, VCSC and VCSE debug diagnostic logs.
3372
