Cisco Jabber on CUCM 8.6
Hi Guys
Who knows how to configure Cisco Jabber on CUCM 8.6?
TIA
Cristian
1 ACCEPTED SOLUTION
Blue
Re: Cisco Jabber on CUCM 8.6
Are you using "Host Name " for CUCM or IP address in System > Server.
If using host name, please remove it and use IP paddress. It should resolve the issue.
Also in CUPS
Change the Host name to IP address in the cluster topology.
After the above change, restart the XCP config and XCP router server
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Exist the Cisco Mobile (Jabber) for Windows??
TIA
Cristian
Hall of Fame Super Silver
jabber for windows is not available yet. You would need either WebEx connect or CUPC client, Jabber for windows is coming soon.
Hth,
Chris
Hi Chris
Thanks for you answer.
Cristian
Who knows how to configure Cisco Jabber on CUCM 8.6? Who has a configuration guide?
Help.
TIA
Cristian.
Are you asking for Jabber for iPhone or Jabber for MAC?
Chris
Hi Chris
For Mac OS.
TIA
Cristian
Are you using CUPS server or WebEX with your deployment as Jabber requires either CUPS or hosted backend system?
You need to build a Client Service Framework (CSF) device similarly to a physical phone on CUCM and associate it with the end user.
Chris
I´m using CUPS. I have a CUCM BE too. For the CSF client, In the device name what information use?, I can´t find detail information about of how to configure...
TIA
Cristian.
use the userID, but technically you can use anything. So, device name would be CSF+username.
Chris
Dear Chris
I made a lot of configuration in the CUPS and CUCM, and Jabber client now shows
"connection refused". Any idea?
TIA
Cristian.
Hey Guys
Any idea?
TIA
Cristian.
Blue
Also in CUPS
Ronak Patel
Dear Ronak
You are great..!!. It´s working right now.
Thanks a lot.
Cristian.
3395
