Cisco Jabber
Hi Team,
Hope you are doing well,
user can't able to send the attachment file throgh iphone or android.
From PC & laptop no issue .whats the steps i have to follow to Troubleshoot this issue?
Mir
1 ACCEPTED SOLUTION
You are most welcome! Please rate the useful posts.
Aseem
Hi Mir,
Hi Mir,
Please check the "Multisite Deployment with Centralized Call Processing" section of the design guide below
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab10/collab10/models.html#pgfId-1043616
Manish
Thanks manish for quick
Thanks manish for quick responce
You have two options either you can use unity connection for auto attendant at the HQ and have Cisco unity express as IVR on Branch CME routers or you can just use CUC at the HQ for auto attendant for all the calls. The calls for AA numbers for all sites in the second scenario can be forwarded to CUCM and then CUC by branch CME routers.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/administrator/AA_and_VM/guide/vmadmin_book/AAttnd.html
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity_exp/design/design21/cuedg21/cueaades.html
Aseem
Thanks aseem for clear
Thanks aseem for clear suggestion.
Appreciate !!!
Aseem
45
