Cisco JabberC SDK
As far as I Know Cisco JabberC is at the moment in the Beta phase, is there already an SDK available.
if yes were can I download the SDK
IF no when will it be released
Thx
Alex
Everyone's tags (1)
1 ACCEPTED SOLUTION
Cisco JabberC SDK
Alex, you are correct JabberC (which is the project name) is currently in the Early Adopter Program (EAP). Currently there is a Web SDK that allows you to embed JabberC into your web applications and we plan to release a mobile SDK for iOS and Android in the next month or so that will allow you to embed JabberC into your mobile apps.
If your interested in joining Project JabberC EAP Beta I've provide some instruction below.
You must join the Collaboration User Group first if you haven’t already, and then you will have access to the private Collaboration User Group where you can register for the Project JabberC Beta.
1.     Please go to the Cisco Collaboration User Group public landing page: https://communities.cisco.com/community/technology/collaboration/usergroups?view=overview
2.     If you are already a Collaboration User Group member,  login with your Cisco.com (CCO) ID.
3.     If you are not currently a Collaboration User Group member,  follow the instructions to join the user group.
4.     Once you’ve logged in, click on the link “Go to the private community to participate”
5.     Once you are in the Private - Collaboration User Group space, scroll down to the “Pre-release Product Trials” section and select the “Pre-release Trial Signup and Access” button.
6.     Select the Project JabberC Beta, read the requirements and register for the beta
Cisco JabberC SDK
Cisco JabberC SDK
Thx for feedback
Alex
692
