CME 8.6 Setup for Jabber for iPhone
Hi, I am trying to set up Cisco Jabber for iPhone with CME 8.6.
I have added the following config for the phone setup:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
  call service stop
sip
  bind control source-interface Vlan100
  bind media source-interface Vlan100
  registrar server
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice register global
mode cme
source-address 192.168.10.1 port 5060
max-dn 10
max-pool 10
load 7971 term71.default
authenticate register
authenticate realm domain.com
timezone 13
hold-alert
mwi stutter
mwi reg-e164
voicemail 200
tftp-path flash:
create profile sync 0002786274701508
voice register dn  1
number 207
call-forward b2bua busy 200
call-forward b2bua noan 200 timeout 20
call-forward b2bua unregistered 200
name Test
no-reg
label 207
voice register pool  2
registration-timer max 720 min 660
id mac 9028.E56F.C414
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username iPhone password 1234
codec g711ulaw
When I try to connect using SEP9028E56FC414 in device ID, I get "unable to verify account" on the iPhone and the TFTP debugging on the router shows:
000224: Jun  6 10:58:08.051: TFTP: Looking for CTLFile.tlv
000225: Jun  6 10:58:08.083: TFTP: Looking for SEP9028E56FC414.cnf.xml
000226: Jun  6 10:58:08.083: TFTP: Opened flash:/SEP9028E56FC414.cnf.xml, fd 14, size 3103 for process 72
000227: Jun  6 10:58:08.151: TFTP: Finished flash:/SEP9028E56FC414.cnf.xml, time 00:00:00 for process 72
000228: Jun  6 10:58:08.203: TFTP: Looking for CUPC/AppDialRules.xml
000229: Jun  6 10:58:08.243: TFTP: Looking for CUPC/DirLookupDialRules.xml
Can anyone tell me what I'm doing wrong?
Sean
I had the exact same issue and was trying to register from the data wireless network (not the voice wireless)
Once the iPhone was connected to the wireless on the same subnet of the Voice vlan, all worked a treat.
Hope that helps
Cheers
Richard
Have followed the above instructions, but I'm still getting "Unable to verify account" on the iPhone and "Looking for CUPC/DirLookupDialRules.xml" on the UC500 TFTP debug. I have the iPhone connected to the Voice VLAN, am getting an address of 10.1.1.12 and can ping 10.1.1.1 from the phone.
hi,
testing :
no codec g711ulaw.
codec g729r8
no create profile
create profile
end
Put the informations as bellow on Jabber:
Device ID: SEP9028E56FC414 (SEP)
TFTP Server: 192.168.10.1
Use Authentication ON
User Name: iPhone
Password: 1234
testing:
voice service voip
ip address trusted list
  ipv4 10.0.0.0 255.0.0.0
  ipv4 192.168.10.0 255.255.255.0
mode cme
source-address 10.1.1.1 port 5060
voice register pool  1
number 1 dn 1
dtmf-relay rtp-nte
username 2302 password 2302
If your Jabber is requesting the dialrules xml files, let's configure them:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmelabel.html#wp1059506
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Guys,
I have successfully implemented jabber for CME with amazing results.
Only issue i have now is that the jabber configuration is locked on the phone and i cannot seem out figure how to unlock it to edit settings like directory.
I am currently pointingthe directory to our Active directory which requires authentication but i cannot enter the credential under voice register template.
Any help please.
Paul
Did you managed to resolve this problem? If so, you can share with the Community how you did it.
Jorge Armijo
Hi, Try this:
number 1 dn 1
dtmf-relay rtp-nte
username 207 password 1234
codec g711ulaw
Hope this helps.
Cheers.
Re: CME 8.6 Setup for Jabber for iPhone
forgot to apply this cml:
create profile under Voice Register Global
Hope this helps.
I was having issues getting Jabber for iPhone working and this fixed it.  Does MWI work for you with Jabber on the iPhone?
I should note mine is in a shared line configuration with a sccp phone on CCME Version 9.1.
Hi !!
I'm using EasyVPN to remote connect on my 1861, and I have this problem too.
IPSec VPN Connection is OK, I'm able to open any LAN  local resource, I've tried any possible combination but I'm always receiving "unable to verify account".
I've tried similar configuration on a 887W and works perfectly (CME 9.1) but on CME 8.6 I'm getting this error.
At the end, I'm always running "create profile" under voice register global anytime I do changes in my configuration.
Hello, I understand the problem you have when you connect by vpnclient, if so, this happens because the vpnclient're riding on the vlan 1 (data), not on vlan 100 (voice). I spend a configuration of vpnclient where settles on the vlan 100.
AAA authentication login default local
AAA authentication login sdm_vpn_xauth_1 local
AAA authentication login ciscocp_vpn_xauth_ml_1 local
AAA authentication login ciscocp_vpn_xauth_ml_2 local
AAA authorization exec default local
AAA authorization network sdm_vpn_group_1 local
AAA authorization network ciscocp_vpn_group_ml_1 local
AAA authorization network ciscocp_vpn_group_ml_2 local
Crypto isakmp policy 3
256 aes encr
authentication pre-share
Group 2
Crypto isakmp client configuration group EZVPN_GROUP_1
key cisco1234
DNS 8.8.8.8
pool pool_vpnclient
ACL pool_vpnclient
Crypto isakmp profile ciscocp-ike-de-1
match identity group EZVPN_GROUP_1
client authentication list sdm_vpn_xauth_1
ISAKMP authorization list sdm_vpn_group_1
client configuration address respond
virtual-template 1
Crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
Crypto ipsec transform-set ESP-3DES-SHA1 esp-3des esp-sha-hmac
Crypto ipsec profile CiscoCP_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-de-1
interface Virtual-Template1 type tunnel
IP unnumbered vlan 100
tunnel mode ipsec ipv4
protection profile ipsec tunnel CiscoCP_Profile1
IP local pool pool_vpnclient 192.168.30.1 192.168.30.254
IP access-list extended pool_vpnclient
permit ip 192.168.10.0 0.0.0.255 any
permit ip 10.1.1.0 0.0.0.255 any
Best regards
10715
