Cnetralization of Jabber Logs
We just rolled out Jabber at our company and our compliance came back to us saying that we need to have a way of able to archive the Jabber logs at a centralized location and be able to retrieve it for compliance purposes. I did a lot of research and found out where the Jabber logs are stored locally under the pc. However I was expecting a text document but I see the history file as a .db file. I did some research and was able to open that with a SQL Lite browser. Does cisco Jabber have any capability of centralizing the History from all the users at the CUPS/Jabber server so we can retrieve it. Would we need to work with third party or buy something from cisco to accomplish this. Any help will be highly appreciated.
1 REPLY
Yes, but you need to configure a postgresql server and DB for that, since you don't mention which version you're using, just go to cisco.com and search postgresql to get the links, only CUPS/IM&P use it, so it's fairly easy to get them.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
230
