Connection settings lost, Jabber 9.2.1
mcaldogne
Level 3
Level 3
We have a sporadic problem with the jabberLocalConfig.xml file.
By start of the PC Jabber cannot find jabberLocalConfig.xml and Jabber create a new file without the connection settings. The user means that he typed the wrong password!
Here the part of log file of a PC where this issue is happened:
2013-06-28 17:14:09,081 INFO  [0x000013d4] [hubwindowplugin\HubWindowPlugin.cpp(876)] [plugin-runtime] [OnSystemShutDown] - Shutting down Jabber in response to a Windows event.
2013-06-28 17:14:09,081 DEBUG [0x00001304] [common\processing\TaskDispatcher.cpp(29)] [TaskDispatcher] [Processing::TaskDispatcher::enqueue] - Enqueue TelephonyAdapter::ProcessPowerEventImpl - Queue Size: 0
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [\services\impl\ConfigServiceImpl.cpp(34)] [ConfigServiceImpl] [ConfigServiceImpl::getConfig] - getConfig key : [RobustShutdown]
2013-06-28 17:14:09,081 DEBUG [0x00001304] [s\VoicemailSystemMonitorObserver.cpp(41)] [VoicemailService] [VoicemailSystemMonitorObserver::onPowerEvent] -
2013-06-28 17:14:09,081 DEBUG [0x00001408] [\TelephonyAdapterAuthentication.cpp(719)] [TelephonyAdapter] [TelephonyAdapter::ProcessPowerEventImpl] - POWER_DOWN Event detected
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [\services\impl\ConfigServiceImpl.cpp(81)] [ConfigServiceImpl] [ConfigServiceImpl::findConfig] - findConfig key : [RobustShutdown]
2013-06-28 17:14:09,081 INFO  [0x00001408] [control\CallControlManagerImpl.cpp(2102)] [csf.ecc.api] [ecc::CallControlManagerImpl::getConnectionStatus] - getConnectionStatus() = eReady
2013-06-28 17:14:09,081 DEBUG [0x00001304] [src\framework\ServicesDispatcher.cpp(45)] [services-dispatcher] [ServicesDispatcher::enqueue] - ServicesDispatcher.enqueue: class CSFUnified::CallbackTask<enum CSFSystemMonitor::PowerEventTypeEnum::PowerEventType,class CSFUnified::VoicemailAdapter> [04183548]
2013-06-28 17:14:09,081 DEBUG [0x00001408] [e\TelephonyAdapterAuthentication.cpp(89)] [TelephonyAdapter] [TelephonyAdapter::Disconnect] - Disconnecting...
2013-06-28 17:14:09,081 INFO  [0x00001408] [control\CallControlManagerImpl.cpp(1983)] [csf.ecc.api] [ecc::CallControlManagerImpl::disconnect] - disconnect()
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [rc\services\impl\ConfigValueImpl.cpp(30)] [ConfigValueImpl] [ConfigValueImpl::setConfig] - setConfig value : [FALSE]
2013-06-28 17:14:09,081 INFO  [0x00001408] [control\CallControlManagerImpl.cpp(2000)] [csf.ecc] [ecc::CallControlManagerImpl::doDisconnect] - --->
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [pters\config\ConfigStoreManager.cpp(144)] [ConfigStoreManager] [ConfigStoreManager::storeValue] - key : [hubvisible] value : [FALSE]
2013-06-28 17:14:09,081 INFO  [0x00001408] [pper\DeskPhoneConnectionContext.cpp(228)] [csf.ecc] [ecc::DeskPhoneConnectionContext::stop] - DeskPhoneConnectionContext::stop
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [common\processing\TaskDispatcher.cpp(29)] [TaskDispatcher] [Processing::TaskDispatcher::enqueue] - Enqueue ConfigStore::persistValues - Queue Size: 0
2013-06-28 17:14:09,081 DEBUG [0x00001408] [pper\DeskPhoneConnectionContext.cpp(829)] [csf.ecc] [ecc::DeskPhoneConnectionContext::DPLogoutWorkItem::DPLogoutWorkItem] - create DPLogoutWorkItem
2013-06-28 17:14:09,081 DEBUG [0x000013d4] [apters\config\ConfigStoreManager.cpp(86)] [ConfigStoreManager] [ConfigStoreManager::getValue] - key : [hubvisible] skipLocal : [0]  value: [FALSE] success: [true] configStoreName: [localFileStore]
2013-06-28 17:14:09,081 DEBUG [0x00001360] [ers\config\LocalFileConfigStore.cpp(172)] [LocalFileConfigStore] [LocalFileConfigStore::createConfigDirectory] - LocalFileConfigStore::createConfigDirectory()
2013-06-28 17:14:09,081 DEBUG [0x00001510] [pper\DeskPhoneConnectionContext.cpp(834)] [csf.ecc] [ecc::DeskPhoneConnectionContext::DPLogoutWorkItem::run] - Run DPLogoutWorkItem
2013-06-28 17:14:09,081 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CDPLine::Close -- begin:
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPLine::SendRequest -- begin:
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- begin: , msg.sequenceNumber=15, pObject=0x0665E07C, pdunames[msg.msgID]=LINE_CLOSE_REQUEST
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest setting msg.sequenceNumber to , msg.sequenceNumber=15
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - Message::encode: , msg.protoVersion=655362, msg.msgID=41, sizeof(Header)=32, fixedSize=12, varSize=0
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest Succeed., pdunames[msg.msgID]=LINE_CLOSE_REQUEST, msg.sequenceNumber=15
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- end!
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPLine::SendRequest -- end!
2013-06-28 17:14:09,081 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CDPLine::Close -- end!
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::Close -- begin:
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::GetLines -- begin:
2013-06-28 17:14:09,081 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::GetLines -- end!
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- begin: , msg.sequenceNumber=16, pObject=0x0665E07C, pdunames[msg.msgID]=LINE_CLOSE_REQUEST
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest setting msg.sequenceNumber to , msg.sequenceNumber=16
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - Message::encode: , msg.protoVersion=655362, msg.msgID=41, sizeof(Header)=32, fixedSize=12, varSize=0
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest Succeed., pdunames[msg.msgID]=LINE_CLOSE_REQUEST, msg.sequenceNumber=16
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- end!
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPLine::SendRequest -- end!
2013-06-28 17:14:09,096 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CDPLine::Close -- end!
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::SendRequest -- begin:
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- begin: , msg.sequenceNumber=17, pObject=0x066AEEF4, pdunames[msg.msgID]=DEVICE_CLOSE_REQUEST
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest setting msg.sequenceNumber to , msg.sequenceNumber=17
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - Message::encode: , msg.protoVersion=655362, msg.msgID=22, sizeof(Header)=32, fixedSize=12, varSize=0
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest Succeed., pdunames[msg.msgID]=DEVICE_CLOSE_REQUEST, msg.sequenceNumber=17
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::SendRequest -- end!
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPDevice::Close -- end!
2013-06-28 17:14:09,096 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::Close -- begin:
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - CDPProvider::SendRequest -- begin: , msg.sequenceNumber=18, pObject=0x069BADDC, pdunames[msg.msgID]=PROVIDER_CLOSE_REQUEST
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest setting msg.sequenceNumber to , msg.sequenceNumber=18
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - Message::encode: , msg.protoVersion=655362, msg.msgID=9, sizeof(Header)=32, fixedSize=4, varSize=0
2013-06-28 17:14:09,096 DEBUG [0x00001510] [src\deskphoneprovider\phonelog.cpp(45)] [csf.ecc] [prepareFor2GLogger] - SendRequest Succeed., pdunames[msg.msgID]=PROVIDER_CLOSE_REQUEST, msg.sequenceNumber=18
2013-06-28 17:14:09,096 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CtiConnection::stop
2013-06-28 17:14:09,096 INFO  [0x00001510] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CtiConnection: deleting connection thread!
2013-06-28 17:14:09,096 WARN  [0x00001518] [src\deskphoneprovider\phonelog.cpp(39)] [csf.ecc] [prepareFor2GLogger] - CtiConnection: CTI connection has shut down unexpectedly
2013-06-28 17:14:09,096 ERROR [0x00001518] [src\deskphoneprovider\phonelog.cpp(36)] [csf.ecc] [prepareFor2GLogger] - CtiConnection: Socket disconnect failed!
2013-06-28 17:14:09,096 ERROR [0x00001518] [src\deskphoneprovider\phonelog.cpp(36)] [csf.ecc] [prepareFor2GLogger] - onDisconnected
2013-06-28 17:14:09,096 INFO  [0x00001518] [src\common\thread\WorkerThread.cpp(115)] [csf.ecc] [run] - Finishing thread: CtiConnection
2013-06-28 17:14:09,096 INFO  [0x0000150c] [src\deskphoneprovider\phonelog.cpp(42)] [csf.ecc] [prepareFor2GLogger] - CtiConnection::stop
2013-07-01 07:51:22,187 DEBUG [0x00001348] [rc\LegacyLocalFileStoreConverter.cpp(29)] [jabberutils.LegacyLocalFileStoreConverter] [LegacyLocalFileStoreConverter::convertLegacyLocalFileStore] - C:\Users\rbza0038\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config\jabberLocalConfig.xml does not exist. Attempting to migrate 9.1 config
2013-07-01 07:51:22,197 DEBUG [0x00001348] [c\LegacyLocalFileStoreConverter.cpp(129)] [jabberutils.LegacyLocalFileStoreConverter] [LegacyLocalFileStoreConverter::logConfigMap] - logging converted data to be saved to xml
2013-07-01 07:51:22,197 DEBUG [0x00001348] [c\LegacyLocalFileStoreConverter.cpp(136)] [jabberutils.LegacyLocalFileStoreConverter] [LegacyLocalFileStoreConverter::logConfigMap] -
2013-07-01 07:51:22,197 DEBUG [0x00001348] [c\LegacyLocalFileStoreConverter.cpp(168)] [jabberutils.LegacyLocalFileStoreConverter] [LegacyLocalFileStoreConverter::writeXmlFile] - data converted to new file and xml format
2013-07-01 07:51:22,197 INFO  [0x00001348] [src\JabberApp.cpp(28)] [jabber-app] [start] -
Starting new instance of Cisco Jabber
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [lugin-runtime\impl\PluginRuntime.cpp(93)] [plugin-runtime] [initialize] - Initializing plugin runtime.
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [c\plugin-runtime\impl\JabberPrt.cpp(319)] [plugin-runtime] [initializePRT] - Initializing PRT hook.
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [rc\plugin-runtime\impl\JabberPrt.cpp(47)] [plugin-runtime] [InitalizePRTRelatedFilePaths] - PRT related files - Ini: C:\Users\rbza0038\AppData\Local\Temp\JabberPRT.ini
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [c\plugin-runtime\impl\JabberPrt.cpp(293)] [plugin-runtime] [createIniFile] - Creating the initial content of the .ini file.
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [c\plugin-runtime\impl\JabberPrt.cpp(228)] [plugin-runtime] [EnforceFilter] - Memory has been patched for function SetUnhandledExceptionFilter in DLL kernel32.dll
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [c\plugin-runtime\impl\JabberPrt.cpp(228)] [plugin-runtime] [EnforceFilter] - Memory has been patched for function _set_purecall_handler in DLL msvcr90.dll
2013-07-01 07:51:22,299 DEBUG [0x0000132c] [untime\impl\pluginRuntimeConfig.cpp(313)] [pluginRuntimeConfig] [loadPluginsFromConfig] - Loading plugin config: jabber-plugin-config.xml
Any help would be appreciate!
Mirko
6 Replies 6
matthwri
I second this. I am seeing 3 other customers with this same issue since upgrading to Jabber 9.2.x (x = 1 and 2) for Windows.
No antivirus or encryption software running that would affect the Roaming Folder.
I will be checking their GPO's personally soon but they have told me no policies are active.
Running out of ideas, any help on this would be appreciated as well.
Thanks for the advice, we will verify if the GPOs are OK.
Maybe the cause could be something wrong in the software distribution!
I'm wondering that more people have not this problem report here.
zerok0ol81
Third this. We have recently migrated from presense clients to the Jabber 9.2.1 client and randomly users will lose their server and login configurations. We have to manually put the info back into the client every time it loses the configuration and is wasting time and frustrating users who want to use the Jabber client.
A solution would be nice.
matthwri
This actually now has a bug attached to it. It is planned to be fixed in Jabber 9.6.
Here is the link to the bug to follow: http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCui26960
Tyler Ronsman
I just recently ran into this as well.  In my scenario I was able to just populate the Jabber-Config.xml file that pulls down from CUCM when the Jabber clients open.  You can add the code in there to remember the Presence Server settings.  The bug doesn't state that it happens when the clients pull down the config file only on JabberLocalConfig.xml.  The Bold part is the Presence Server Config.
example config:
  UDS
  http://server_name.domain/%%uid%%.jpg
  true
  true
  CUP
  SERVER_IP
  DOMAIN
  true
  true
  .exe;.msi;.rar;.zip;.mp3
  false
  presence
Link to Config Parameters:
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_2/JABW_BK_C9731738_00_jabber-windows-install-config_chapter_0101.html#JABW_RF_SBE0DD7D_00
We insered the CUPS parameter in the Jabber-Config.xml but unfortunately we still have the issue.
