07-12-2016 11:20 PM - edited 03-17-2019 06:14 PM
I am trying to register my jabber windows client to CUCM, but I receive the error "The Telephony configuration settings are invalid".
I am not able to apply the TFTP server, CTI server, CCMCIP server informations as I gave in previous jabber versions. Please help me to register my app.
Attached is the screenshot.
Thanks You.
Solved! Go to Solution.
07-20-2016 07:05 AM
Jabber 11.5 only works on CUCM 9.x or later - you have an unsupported setup. You will need to drop to an older version of Jabber until you upgrade your CUCM. Look at the software requirements in the Jabber 11.5 release notes.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/11_5/cjab_b_cisco-jabberwindows-115-release-notes.html#reference_FBF6C698F7E5320B6F935031129D5E20
07-13-2016 07:12 AM
Did you install it, and are you running it, as an Administrator?
07-15-2016 01:42 AM
Yes. We use 9.7.4 here in our client side. But we will be upgrading to 11.5 version in a short time.
Thanks.
07-20-2016 07:05 AM
