CUPS 8 and Jabber Clients (mobile clients)
I've been trying out various Jabber clients (on iPhone, Android and Blackberry). So far I've not
had much luck with any of them. I'm guessing such clients should be supported and for
them most part I've gotten PC and Mac clients to work fine.
My testing is done here in the office over local wireless connection so I know its not a network
issue. The clients simply will not connect.
Anyone had any luck with any of these type of clients and CUPS 8?
Red
Re: CUPS 8 and Jabber Clients (mobile clients)
Have you tried any Jabber client from a Windows PC?
Michael
http://htluo.blogspot.com
Yes, I can get clients to work both on Windows and on Mac.
Red
Then it sounds like client issue.
You may take a look at "Connection Manager Logs" and "XCP Authentication Logs" from CUPS server.
Michael
It looks like many of the Jabber mobile clients work with an external server rather than directly. I've found OneTeam for iOS works well but nothing otherwise for Android or Blackberry.
1131
