Deploy audio settings in JFW 10.5, 11.6 and 11.7
Hi all
Are there still no way to deploy standard audio settings in JFW 10.5? (File->Options->Audio)
All of our users are using the same headsets, and we could save alot of time if we could deploy these headset settings.
/Kristian
Everyone's tags (1)
No news on this one? What do
What do others do? set the settings up manually?
Best regards
Kristian
Anyone? Do you all set the
Anyone?
Do you all set the settings up manually.
Best regards
Kristian
Hi Kristian,
Hi Kristian,
Did you find any solution for this issue by your own? I am in the same situation.
Thanks and regards
No :( but its working better
No :( but its working better in J4W 11.6 and 11.7. Also, Cisco has applied a couple shortcuts to the Audio Settings menu.
But still, it would be nice if we could deploy the settings somehow.
What do other firms do here? Must the end user set the audio settings by them self, or do their IT do it?
Do new coworkers get an manual?
Best regards
K.
102
