Difference between CUPC and Jabber for Windows
Following I have found so far
1) Jabber for Windows doesn't CUPS LDAP as CUPC does
2) Jabber for Windows doesn't always use Application Dial rules from CUPS as CUPC does
3) Jabber for Windows does not support sRTP (no CAPF)
4) Jabber for Windows does not support Deskphone Video
Anyone knows of some other limitation of Jabber for Windows that CUPC doesn't have?
  • Jabber Clients
Everyone's tags (5)
1 ACCEPTED SOLUTION
Super Bronze
A couple of others:
1) In Jabber you can't add your own contacts (e.g. your Mum) or anyone who isn't on CUPS
2) Can't enable 'In a meeting' status from within the application
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Re: Difference between CUPC and Jabber for Windows
In reply to my own discussion
It would be nice to have summary of roadmap for major features. Most customer have the impression moving from CUPC to Jabber for Windows would retain most feature set.
Super Bronze
A couple of others:
1) and 2) in the latest post ('Pizza guy/Mom' contacts and enabling/disabling 'In a Meeting') are both targeted for the 9.1 release as are Deskphone video and sRTP.
1) and 2) in the original post should be supported today so please post any issues to the relevant mailers to get a resolution.
John
For explanation -
1) Jabber for Windows doesn't CUPS LDAP as CUPC does.
- Jabber for Windows does not user CUPS LDAP profile configuration as CUPC 8.x does. It either automatically discovers or uses jabber-config.xml file
- Doc here -
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_0100.html#concept_F752432E9F06485EA773F8095CD7EEA5
"If Cisco Unified Communications Manager does not publish the dial rules that you create to Cisco Jabber for Windows,"
It did not do a good job in stating which version of call manager we need to run the cop file though. Does anyone know?
HI!
I've installed the version 9.1 of Jabber for Windows, however I cannot add external contact (Pizza guy, Mom). Deskphone Video doesn't work too.
CUCM 8.6(2)
CUPS 8.6(3)
Deskphone Video:
Please check "Desk Phone Video Configuration" section in the admin guide. Also check the section "Desk Phone Video Capabilities" in 9.1 Release Notes for considerations and limitations that apply to desk phone video capabilities. Medianet is mandatory to install for deskphone video feature.
External (Pizza guy) contacts:
External contacts feature has unfortunately been pushed out to 9.2 release (in 1st half of CY2013). 9.1 supports Outlook contact search (users can search for, add, and communicate with local contacts from Microsoft Outlook).
As  a workaround you can add these contacts in Outlook and then access them  via Jabber. Note that these contacts should have an IM or email address so that  they could be searched and added in Jabber. If after adding such contact  you don't see them in contact list, then make sure that "Show offline  contacts" is checked in the View menu. I know its not ideal but  something you can work with until "Personal contacts" feature is  available.
Maqsood
Hi Maqsood!
Thank you for your reply.
Deskphone Video:
I've configured the Phone as described in the admin guide and I've also installed the medianet  file.
Now the computer is connected to  the PC port of the ip-phone, under help-connection status, "video for deskphone" is connected. Anyway, when I call from Jabber another user with Jabber and video for deskphone enable works only audio.
When I call a user with Jabber as softphone or a phone with integrated camera, the other user can see me but I cannot see him.
External contacts:
the Outlook integration is nice, but unfortunately the most users have Lotus Notes. I will wait for the release  9.2 and I hope it will be available as soon as possible.
Mirko
Hi Mirko,
Please make sure that Medianet service is running on the machine.
  • Go to the Services on your PC
  • Manage Computer -> Sevices and Applications
  • Then look for Cisco Media Services and check that it is enabled and started.
If it is not started then right click on the service and click start. If it is already started then please open a support case with Cisco TAC for further assistance.
Maqsood
Hi  Maqsood!
I have opened a TAC support case for the problem with deskphone video.
Now I 've a new problem with the outllook contacts on my PC: last week I added one contact to my Jabber to test this feature, I added also a picture and all works good.
But now I can't add any contacts, I configured e-mail or IM-address but in Jabber I can't find these contacts in the directory search (the test contact I added last week too).
Can you help me?
Thanks a lot,
Mirko
11266
