Display telephone / home number when using UDS?
Hi guys,
CUCM is integrated with AD and when using EDI directory on Jabber, I can map several phone numbers which show up on the user profile in Jabber.
We switched this to UDS directory because of some issues with users outside the domain, but now each user shows Work (their DN) and Mobile number, but not the telephone number, home number, fax number etc. Is there any way to do this on UDS or is this just a limitation of using UDS over EDI?
Sean
You only get that phone number if using UDS, to get all the other DNs, you need EDI.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Re: Display telephone / home number when using UDS?
Thanks Jaime - though it seems to populate the mobile number correctly even when using UDS?
268
