Embedded Tab Custom Icon (Picture Problem)
I'm having an issue getting my custom icon url picture to show up correctly. I resized using paint 20x20, even tried 19x19 and saved in png format. Jabber downloads the picture but it's tall and narrow. I can barely make out the picture. I read something about adding padding but have no clue what that means. Any help is appreciated. Thanks!
Bronze
something similar was
something similar was discussed in the following link;
https://supportforums.cisco.com/discussion/11590996/icons-custom-embedded-tabs-jabber-windows
look at the last reply where the following was mentioned;
Any image editor can be used to create icon. Foe example use online editor pixlr (http://pixlr.com/editor/).
  • Create 20x20 image for every state (Normal, Pressed, Hover e.t.c) of your icon.
  • Create a new 200x20 image
  • Add the different state images to this image as layers
i hope this helps.
Thank you amitk3! I am trying
Thank you amitk3! I am trying to use pixlr but I don't see how to change the color to the hexidecimal codes in the configuration guide. Can you shed some more light on using pixlr? Thanks for your help!
Hi, here is a cisco support
Hi, here is a cisco support forum icon set based on the favicon.ico file for use within Jabber.  You can use it as is, or use it as a learning aid.
Anthony Holloway
Please use the star ratings to help drive great content to the top of searches.
325
