03-17-2015 09:23 AM - edited 03-17-2019 04:59 PM
I'm trying to create a TLS neighbor zone between Exp-C and Jabber Guest. I have my own internal CA signed certs on JG and Exp, but TLS is failing and Exp is throwing this error in the logs: No SSL error available, probably remote disconnect. TCP works fine. I've generated the CSR twice for JG and rebooted twice as well. Not sure what is going on. Thanks, Mike
03-17-2015 09:44 AM
Ah, needed to read a little further in the JG install guide :) I forgot to upload the CA root cert. I would recommend adding this step to the install guide prior to configuring the neighbor zone on the expressway (or at least a note about it). Then the neighbor zone won't error out.
03-18-2015 02:17 PM
Mike - Thanks for the recommendation. We'll look to update the docs accordingly the next time we rev them.
Mike
03-19-2015 07:08 AM
just to clarify. Are you talking about uploading the CA root cert on the Expressway or the JG server?
03-19-2015 08:56 AM
JG Server. Expressway had already been fully configured including the CA root cert.
