Expanding text box
IBM's SameTime has a feature that allows users to expand the text box to review a larger message prior to submitting (please see attachments). Does Cisco Jabber have a similar feature? Would Cisco Jabber implement a similar feature?
Jared Roundy
Hover over the limit between
Hover over the limit between the chats you've sent and the input box and you should be able to make it a bit bigger, but in mine, only got about 5 lines, that's seems to be as big as it gets. 3 lines seem to be the default.
If you want a feature to be considered for a future version, you need to reach out to your AM to submit a PER.
java
if this helps, please rate
www.cisco.com/go/pdi
Do you know how I may find
Do you know how I may find out who my AM is?
48
