IM&P > Presence > Settings > Advanced Settings change IM to email warning?
This screenshot below/attached worries me.  New Deployment of IM&P 10.0.1 with Jabber for Windows 9.7.1  Under Presence > Advanced Settings if I change the IM address I get a pop-up warning about  “All clients must be capable of supporting Directory URI as IM Address Scheme. Do not change this setting if you have any clients that do not support the new address scheme”
Basically our sAMAccountName is short name, and our Chat IM Address we want to be email based, and our CUCM LDAP Directory > Directory URI = email
Are any new Jabber clients not capable of supporting Directory URI as the IM Address? Eg Jabber for iPhone/iPad/Mac/Android/Blackberry ? I assume this message is for older software versions?
To add to my misery after
To add to my misery after trying to change it ;
"im address scheme change failed"
Can't recall which one, but I
Can't recall which one, but I believe that as of today, only one Jabber client supports it.
java
if this helps, please rate
www.cisco.com/go/pdi
Hi Jaime I have an problem
Hi Jaime
I have an problem with outlook the proxyaddress have multidomain, therefore the presence outlook is false, my solution is upgrade cucm and IM&Presence to version 10.5, this support mutidomain with IM address URI, but the cisco tac,currently no Jabber clients support directory URI address scheme, this is true?
Correct multi-domain is not
Correct multi-domain is not currently a feature despite all the documentation alluding otherwise.
https://tools.cisco.com/bugsearch/bug/CSCuo95266
Hi Jasonthanks for your
Hi Jason
thanks for your answer in the bug says the version 10.5 supports this feature, this version is now available, this is true? or jabber 10.5 not support multi-domain?
Jason,Here is an extract from
Jason,
Here is an extract from the installation guide for IM&P:
Caution
If you configure the node to use Directory URI as the IM address scheme, Cisco recommends that you deploy only clients that support Directory URI. Any client that does not support Directory URI will not work if the Directory URI IM address scheme is enabled. Cisco recommends that you use the UserID@Default_Domain IM address scheme and not the Directory URI IM address scheme if you have any deployed clients that do not support Directory URI.
If I am not wrong the latest versions of Jabber do support Directory URI as the IM Address.
Below you'll find the documentation that I mentioned before:
http://tools.cisco.com/squish/037b4
Hope this helps!
- Miguel Aikens
Although server-side IM&P 10
Although server-side IM&P 10.0 supports multi-domain, the Jabber clients did not add this feature until 10.6.  However looks at if it is fully supported across all of the Jabber clients at this time:
Feature name = multi-domain = Flexible Jabber ID = Directory URI support.
Jabber for Mac 10.6 Release Notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/mac/10_6/JABM_BK_C6D012D7_00_cisco-jabber-for-mac-106.html#JABM_RF_F65F8D61_00
Jabber for Android 10.6 Release Notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Android/10_6/rn/JABA_BK_CB805EB4_00_cisco-jabber-for-android-10-6-release_notes.html#JABA_RF_NCAFF4FB_00
Jabber for iPhone and iPad 10.6 Release Notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/iPhone_iPad/10_6/RN/JABI_BK_CF3573C2_00_cisco-jabber-for-iphone-and.html#JABI_RF_N61CB8E5_00
Jabber for Windows 10.6 Release Notes
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Windows/10_6/rn/JABW_BK_C6A8A6C3_00_cisco-jabber-for-windows-10_6-release-notes.html
Flexible Jabber ID—Cisco Jabber 10.6 supports multiple presence domain architecture models for on premises deployments when the domains are on the same presence architecture, for example users in example-us.com and example-uk.com.
To support multi domain models, all components of the deployment require the following versions:
    Cisco Unified Communications IM and Presence server nodes and call control nodes version 10.x or later.
    All Cisco Jabber clients on Windows, Mac, IOS and Android version 10.6 or later.
Only deploy Cisco Jabber with multiple domain architecture in the following scenarios:
Cisco Jabber 10.6 or later is deployed as a new installation to all users in your organization on all platforms (Windows, Mac, IOS and Android, including Android based IP Phones such as the DX series).
Before making any domain or IM address changes on the presence server, Cisco Jabber is upgraded to version 10.6 or later for all users on all platforms (Windows, Mac, IOS and Android, including Android based IP Phones such as the DX series).
When setting up Cisco Jabber the Jabber ID that identifies the users can be mapped to the Directory URI field on Cisco Unified Communications Manager. This allows Cisco Jabber to identify the users by their AD mail attribute or the AD msRTCSIP-primaryuseraddress attribute. A user can log into Cisco Jabber with their sAMAccountName attribute, while the Jabber ID is mapped to the Directory URI field. For more information see the IM Address Scheme section in the Cisco Jabber 10.6 Deployment and Installation Guide.
2238
