J4W - Set Jabber to handle CALLTO: Protocol?
How can I set Jabber to handle callto: hyperlinks? I was able to get Jabber to launch when I click a callto: hyperlink but it will not actually call the number. TEL: works fine but I am trying to get callto: to function as well.
Thanks for any help you can provide.
You can't we don't register
You can't we don't register that handler
Cisco Jabber registers the following protocol handlers with the operating system to enable click-to-call or click-to-IM functionality from web browsers or other applications:
  •  XMPP: Starts an instant message and opens a chat window in Cisco Jabber.
  •  IM: Starts an instant message and opens a chat window in Cisco Jabber.
  •  TEL: Starts an audio or video call with Cisco Jabber.
  • CISCOTEL: Starts an audio or video call with Cisco Jabber.
  • SIP: Starts an audio or video call with Cisco Jabber.
  • CISCOTELCONF: Starts a conference call with Cisco Jabber.
java
if this helps, please rate
www.cisco.com/go/pdi
This is a reg file for
This is a reg file for windows 7 we used to enable SIP. LYNC kept getting in the way.
I think you could change the SIP/SIPS to tel and make sure everything points to the correct exe.
HKEY_CLASSES_ROOT\sip]
@="URL:Sip Protocol"
"URL Protocol"=""
[HKEY_CLASSES_ROOT\sip\DefaultIcon]
@="\"C:\\Program Files (x86)\\Cisco\\JabberVideo\\JabberVideo.exe\""
[HKEY_CLASSES_ROOT\sip\shell]
@="open"
[HKEY_CLASSES_ROOT\sip\shell\open]
[HKEY_CLASSES_ROOT\sip\shell\open\command]
@="\"C:\\Program Files (x86)\\Cisco\\JabberVideo\\JabberVideo.exe\" \"%1\""
[HKEY_CLASSES_ROOT\sips]
@="URL:Sips Protocol"
"URL Protocol"=""
[HKEY_CLASSES_ROOT\sips\DefaultIcon]
[HKEY_CLASSES_ROOT\sips\shell]
[HKEY_CLASSES_ROOT\sips\shell\open]
[HKEY_CLASSES_ROOT\sips\shell\open\command]
627
