Jabber 11.6 start in system tray
I've seen some info using older versions, and those solutions do not apply.  Jabber always starts minimized in the taskbar.  Is there a way to have it start to the system tray instead?
Thanks!
Dana
1 REPLY
Dana,
Dana,
       Do you use jabber-config.xml file? If you do, we can try adding a parameter that used to work in the older versions. <HonourLastWindowSate>true</HonourLastWindowSate> - this is the parameter that can be tried. But, remember that users have to click red x on Jabber to minimize it to system tray before the next logon. Then, the above parameter should take effect. Let me know how it goes.
Looks like this:
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
 <Policies>
   <Screen_Capture_Enabled>true</Screen_Capture_Enabled>
   <EnableSIPURIDialling>false</EnableSIPURIDialling>
   <HonourLastWindowState>true</HonourLastWindowState>
   <ctiwindowbehavior>Never</ctiwindowbehavior>
 </Policies>
-Sankar
43
