Jabber 9.0.1 saerch contact issue
Dear Networkers,
We are using Cisco Jabber for windows 9.0.1 with Cisco Unified Presence 8.6 and CUCM 8.6
We are using CUPC 8.6 also.
We can successfully login using Jabber. but we cannot retrieve contacts when searchng.
We have AD integration with CUCM (synchrinisation) and with CUPS done successfully. The wierd the wierd thing is that when we login using CUPC we can search contacts and add them.
Can you please advise ?
Thanks.
  • Jabber Clients
Re: Jabber 9.0.1 saerch contact issue
We had the same symptom when the windows workstations were not in the same domain than the ldap referenced by cups. We had to manually generate a config file as described in jabber config guide
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_0100.pdf
If you are fully integrated into the same AD domain it should not occur.
I also confirm that a CUPC client on the same PC was working fine without any manual config so provisioning process is different b/w CUPC and jabber 9.
Christophe
Hey,
To add to what Chris mentioned, you can also reference the following KB article for EDI deployment:
https://supportforums.cisco.com/docs/DOC-24137
If you are at CUCm 8.6(2), you can also deploy UDS: Configure Cisco Jabber for Windows to use the directory service
Jas
I had same problem, you need to put the config file (attached) on the path C:\Users\yourname\AppData\Roaming\Cisco\Unified Communications\Jabber\CSF\Config and be sure that you can access the presence server by name (dns or hosts file). Before you login you must to configure the presence server by name, not by IP.
Carlos
What field are you using to sync the users from ad?
If it's different from the default sAMAccountname, then you will need to configure it in the jabber-config file.
For futher details, you can check out the docs here:
http://www.cisco.com/en/US/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg_chapter_0100.html#task_FB59C36497704E0F8DCE0C9CD77EBA03
1045
