Jabber 9.0.4 DLL
Trying to install 9.0.4.  I currently have the Beta, 9.0.0  I get the following popup when trying to install
DLL being called encountered a problem.     Heres a piece from the install log
=== Logging stopped: 8/22/2012  14:09:45 ===
MSI (c) (28:EC) [14:09:45:792]: Note: 1: 1708
MSI (c) (28:EC) [14:09:45:792]: Product: Cisco Jabber -- Installation operation failed.
MSI (c) (28:EC) [14:09:45:792]: Windows Installer installed the product. Product Name: Cisco Jabber. Product Version: 9.0.4.10773. Product Language: 1033. Manufacturer: Cisco Systems, Inc. Installation success or error status: 1603.
Probably a windows error, but i figured id ask here.   anyone seen this before?
Everyone's tags (3)
1 ACCEPTED SOLUTION
Jabber 9.0.4 DLL
Did Jabber install after this message? If not you can try below steps.
     1) Click Start, type 'services.msc' and press Enter.
     2) From the window, locate the Windows Firewall service, right-click and click Start.
     3) Uninstall Beta version.
     4) Launch 9.0.4 installer.
This is a know issue in Pre-FCS builds.
Maqsood
Jabber 9.0.4 DLL
Maqsood
Jabber 9.0.4 DLL
Yes indeed.  that fixed the problem, and i have 9.0.4 installed now.  Thanks for your help
1183
