Jabber 9.6 Deployment & Certificates...
Hi Guys,
We are planning to package Jabber 9.6 to the enterprise (approx 4000 machines) and was wondering the best way to take care of the certificates…
Due to high availability, we will see certificates potentially from two CUP Servers, two call managers (PUB & SUB), and two unity servers and potentially a couple of webex servers as well in the future.
What is the “Best Practise” for this scenario without having end users to accept certificates all the time?
I have not had much to do with certificates on a CISCO level so any help much appreciated!
Cheers!
1 REPLY
Certificates are certificates, you find them in a lots of places and are becoming very common, the fact these are Cisco does not matter at all.
You can search the web for how to install certs in bulk to get the answer to your question:
http://www.tomshardware.com/forum/59086-45-installing-certificates-batch-file-possible
http://blogs.msdn.com/b/steverac/archive/2009/07/09/adding-certificates-to-the-local-certificates-store-and-setting-local-policy-using-a-command-line-system-center-updates-publisher-example.aspx
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
710
