Jabber 9.7 certificate validation
Hello all,
I'm trying to get Certificate validation working with J4W 9.7 using IMP v9.1. I was able to get all the Tomcat certs working but struggling on the xmpp cert.
I'm following this guide
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-presence/116917-technote-certificate-00.html
I have the following questions in relation to xmpp cert
  • when i create the CSR do i use cup-xmpp or do i use cup-xmpp-s2s ?
  • The document in the URL above references near the bottom "Provide XMPP Domain to Clients" if our environment uses the same "presence domain" that the server is in I presume i leave this section blank? Example our presence domain is .example.local and the presence server is in "example.local" both nodes in the cluster are using FQDN of "server.example.local"
Everyone's tags (1)
2 ACCEPTED SOLUTIONS
CSR for cup-xmpp has to be
CSR for cup-xmpp has to be used.
cup-xmpp-s2s is "server to server" communication for inter domain federation.
The domain part is very important.
XMPP server certificates have to contain the jabber domain.
If your IM&P server is cups1.example.local and your presence domain is example.local the jabber id will be like user1@example.local. When Jabber connects to the xmpp server the certificate has to be valid for "example.local". A certificate which is only valid for cups1.example.local will create a validation error.
You would need to generate
You would need to generate the CSR for cup-xmpp
Refer to this doc for more info http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-presence/116917-technote-certificate-00.html
454
