Jabber - Add trailing #
fpiccioni
Hi experts
Environment: CM 9.1 with Jabber Users
Often, Jabber users call numbers picking them from their mobile phone directory.
I am looking for a way to automatically insert the trailing # in order to eliminate the waiting time for the interdigit timeout and make the call start immediately.
I tried using Called Party Transformation Mask but CM always waits the interdigit timeout timer before beginning transformation
Does someone knows the way to add trailing # in Jabber or if there is another way to do that?
Dennis Mink
why are you not changing the interdigit time out?
or even better, create a route pattern for mobiles and tick the "urgent priority" box
this will do away with the T302 timer
Please remember to rate useful posts, by clicking on the stars below.
Dennis Mink
Hi Dennis
I prefer to not to change timers.
I created a new Route Pattern with Urgent Priority checked and now waiting time is ok
Thanks for helping
Fulvio
