Jabber - Add trailing #
Hi experts
Environment: CM 9.1 with Jabber Users
Often, Jabber users call numbers picking them from their mobile phone directory.
I am looking for a way to automatically insert the trailing # in order to eliminate the waiting time for the interdigit timeout and make the call start immediately.
I tried using Called Party Transformation Mask but CM always waits the interdigit timeout timer before beginning transformation
Does someone knows the way to add trailing # in Jabber or if there is another way to do that?
  • Jabber Clients
1 ACCEPTED SOLUTION
why are you not changing the
why are you not changing the interdigit time out?
or even better, create a route pattern for mobiles and tick the "urgent priority" box
this will do away with the T302 timer
============================= Please remember to rate useful posts, by clicking on the stars below. =============================
Hi Dennis
Hi Dennis
I prefer to not to change timers.
I created a new Route Pattern with Urgent Priority checked and now waiting time is ok
Thanks for helping
Fulvio
16
