Community Member
Jabber cannot click to dial from Outlook
dials from jabber OK
can't dial from outlook 2007
when click on dial the "new phone call" window opens (instead of directly dialing) and call can not be made
registry key is ok
[HKEY_CURRENT_USER\Software\IM Providers]
"DefaultIMApp"="Cisco Jabber"
Everyone's tags (5)
It sounds like Click to X is not enabled in outlook.
Can you see the presence for the users?
Can you send some screenshots and a prt please?
Katie
Community Member
OK
i checked
i can't see the presence for users from outlook
we get the the following window (ours is in hebrew so...)
Hi Jacob,
That window is actually the Microsoft outlook call window.
It looks like Click to  X did not install on your machine or is disabled.
Do you have CUPC or Cisco Webex client also installed on your machine?
Katie
Community Member
Re: Jabber cannot click to dial from Outlook
thanks
on clients that dont work i above window
and on clicking "start call" i get an error
on clients that work ok i get the following window and call is ok
i dont have cupc or webex on the PC
Hi Jacob,
The second window
is a Cisco Jabber window and is working as designed.
The 1st window you sent
This is not a Cisco window, it is a Microsoft Outlook window.
This would imply that the Cisco Click to X feature is not installed on the affected machine.
Do you have many users with this issue?
Would it be possible to reinstall Jabber on this machine?
Community Member
OK
had two with this problem
1 was corrected by jabber reinstall
on the 2nd reinstall didnt help
are there any services or registry keys i can check  for?
Can you gather a prt from the affected user so I can check if anything is happening in the install to stop the click to x functionality from working.
Katie
Community Member
prt?
Super Bronze
It's Problem Report - it's under the 'Help' menu, click 'report a problem' and follow the wizard. It collects the app logs into a ZIP on your desktop that you can send us/Cisco to get it investigated.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Community Member
where should i send the prt?
Community Member
have posted you a private message with the prt
thanks
Community Member
we had almost the Same Problem...
try to decrease the user Account Security to Zero while you are installing Jabber...before you Need to deinstall AND reboot...
obviusly you Need full administrational rights..
Andreas
Community Member
Machine is Windows XP
has no account sec levels (different then WIN 7)
Hi Jacob,
I took a look at the problem report you sent on and it is still not clear why Click to X is disabled for this user.
Can you create a TAC case for this issue as it requires further investigation.
Thanking you,
Katie
14527
