Jabber cannot control 9971
Hi Guys
Got a weird one. From Jabber we can control its own softphone and 7900 series phones.
We have a new 9971 and despite that Jabber Client says that its Deskphone CTI status is connected, Jabber simply does not control nor respond to the phone at all.
The user of the phone is a member of "Standard CTI Allow Control of Phones supporting Connected Xfer and conf" and "Standard CTI Allow Control of Phones supporting Rollover Mode" groups. The phone device is CTI enabled.
CUP = 8.6.4.13900-4
Jabber Client = 9.2.2 (3271)
I simply cannot work out why this will not work.
Any help appreciated.
Cheers
Mike
Blue
Please do the following
1) restarted CTIManager on the whole cluster;
2) deassociate end user and device and reassociate it again.
3) deleting the phone and let it re-register again, made it work again
Also add “Standard CTI control of All device” to the user profile.
Let me know what firmware is runing on the phone.
Ronak Patel
Rate all helpful post by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Re: Jabber cannot control 9971
Its a bit too hard to do those other tasks during operating hours, cannot see in a prod environment why they would even be required to enable one phone frankly.
sip9971.9-3-4-24
Since this is only happening on a phone I would do the following
-- Verify that the 'allow control of device from cti' is enabled on phone the device and DN configuration pages in CUCM
--  Verify that the DN of the phone is associated with the end user
-- Verify that the primary DN is that of the phone (in the end user pages)
If everything checks out I would need to see a problem report
HTH,
Christos
Keep in mind this is the only 9971 we have enable thus far. All the other phones are 7900's and a few 6900's (SCCP)
Yes CTI is enabled on device and user is assiciated with the DN
The handset only has one DN the correct one. User can access it OK from user pages.
Have now restarted CTI and there is no change.
I should not a specific behaviour though, when a call comes in, Jabber does respond and present the details of the call, just when you click to answer nothing happens on the handset.
The user also has a CSF and the softphone works fine.
Likewise you cannot click to call to control the handset. When you go off-hook jabber responds.
So looks like it is halfway there, just cannot control the handset
Hi Michael,
I am not aware of any issues with the 9971 phones with jabber. Apart from the two CTI Groups which you know already the rest should be the same as in any other phone.
I can think of the following things you can do
-- Assign this phone to another jabber user and see there is any difference
-- FInd another one and try it as well just in case there is a problem with this specific phone
Other than that I will have to look at the ctimanager traces from CUCM and the jabber logs to find out what's going on. If you don't want to attach them feel free to open a TAC SR
HTH,
Christos
Hi Michelassign the following
Hi Michel
assign the following roles to end users for 9971 phones
    standard ccm end user
    standard cti enabled
    standard allow control of all devices
    standard cti allow control of phones supporting transfer and conference
This can fix your issue
At the time using the
At the time using the versions listed, this did not help at all. Cisco doco made this clear too.
In the end we upgraded to versions post 9.1 and the issue is resolved in newer versions.
With which version did you
With which version did you manage to get it to work?
We're having the same problem, and have tried about every Jabber version available, right up to the current 10.6.2
Hi Frank, I have just
Hi Frank,
I have just resolved this issue by adding the following permissions to the user:
Standard CTI Secure Connection
Standard CTI Allow Control of All Devices
We are running CUCM 9.1.2.11900-12
9971 Firmware sip9971.9-4-2SR1-2
Jabber 10.6.2
Gordon
Thank you, that solved it for
Thank you, that solved it for me as well.
I had the same problem with
I had the same problem with 8811 not being controlled by Jabber (10.6.2).
Added permissions to the End-User.
Working great now, thanks !
Added permissions to user, solved the problem.  Thanks!
I had the same issue with the
I had the same issue with the 9971 and added the Standard CTI Secure Connection permission to my user id and now am able to control the phone.
Thank you for your help!
2047
