Community Member
Jabber Chat Lag
Every time I hit Enter to send a chat message in Jabber, it takes 1-2 seconds for the message to send.  When I receive a message, I hear the receipt sound, but the message doesn't show up until a few seconds later.  I started using Jabber a few months ago and this problem has been happening for the past week or two, so it hasn't always been like this.  Prior to a week or two ago, sending and receiving chats was instantaneous.
I am using Jabber 10.5.2 on Windows 8.1
Community Member
Try checking your anti virus.
Try checking your anti virus. I have seen scans hit the hard drive hard causing chat delays like this.
Community Member
i m already checked , my anti
i m already checked , my anti virus is normally
Community Member
While we aren't sure which
While we aren't sure which update caused the issue, we believe there is a correlation between a Windows Update and the slowness. We are having this problem organization-wide for a week or so. Windows 7 and Jabber 10.6.0 - 10.6.2
Community Member
We are having the same issues
We are having the same issues with Windows 7 and Windows 8. Running Jabber 10.5.0 and Jabber 10.6.2. Have you raised this with TAC yet and is so can I get the bugID?
Community Member
I haven't had a chance to
I haven't had a chance to talk to TAC yet about it.
Community Member
Just did some more testing,
Just did some more testing, look like it is related to the latest MS security patches that were rolled out this month. I rolled them all back and it is functioning normally.
Also removing the history file seem to be a temporary work around
Looks like some sort of bug with Cisco and the latest patch, right when the rolled out Skype for Business....timing....
Community Member
It is true, removing history
It is true, removing history solves the problem. But not for long time.
After chatting for 1-2 hours, the problem rises again with the specific person you chat with.
I rolled back to jabber 10.5 or older and still, the same issue.
I have an opened TAC since yesterday.
BTW, which security update have you uninstalled?
Community Member
We have also experienced this
We have also experienced this issue with Jabber 10.5 since Windows patching took place.  I have also experienced a temporary improvement when clearing the chat history.  I'd be very interested in what TAC says.  Thank you.
Community Member
Check this out!https://tools
Check this out!
https://tools.cisco.com/bugsearch/bug/CSCuu02593
Antonis
Community Member
Hello, I've just upgraded to
I've just upgraded to 10.6.4 and the problem is gone. Based on the bug description send by dwtcp (Antonis), the solution is the upgrade to the latest version.
Regards, Dragan
Community Member
I was running 10.6.0, upgrade
I was running 10.6.0, upgrade to 10.6.4 and this corrected my issue as well.
Community Member
Upgrading to 10.6.4 worked
Upgrading to 10.6.4 worked for us as well.  Thank you!
1774
