Jabber client not authenticating outside of network
Everything works inside of our network... ie authenticating with the VCS but not outside the network.
I started a log on the Expressway and then went outside of our network and tried to connect to Jabber.
I have my expressway zones set to do not check credentials and my control settings set to check credentials.
the control is connected to AD.... and the expressway is connected to LDAP (not sure if that matters)
I've got the jabber template set up in TMS with the VCSE address in.
I'm not too technical with this but would anybody be able to help.
This is the log below.. any ideas why it won't log in?
Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:username@company.co.uk, Call-ID=031ac5ef110a3919@127.0.0.1"
2013-08-07T14:24:20+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:20,949" Module="network.sip" Level="DEBUG":  Src-ip="82.132.234.165"  Src-port="39014"
SIPMSG:
|SUBSCRIBE sip:username@company.co.uk SIP/2.0
Via: SIP/2.0/TLS 10.5.161.68:54616;branch=z9hG4bKb90dd0448af3919e2bf7b557b3e264e4.1;received=82.132.234.165;rport=39014
Call-ID: 031ac5ef110a3919@127.0.0.1
CSeq: 201 SUBSCRIBE
Contact: <sip:username@10.5.161.68:54616;transport=tls>
From: <sip:username@company.co.uk>;tag=2c7a45453c26f945
To: <sip:provisioning@company.co.uk>
Max-Forwards: 70
Route: <sip:vcse ip address:5061;lr;transport=tls>
User-Agent: TANDBERG/774 (MCX 4.5.7.16762) - Windows
Expires: 300
Event: ua-profile;model=movi;vendor=tandberg.com;profile-type=user;version=4.5.7.16762;clientid="S-1-5-21-3613096711-2978834610-2195627325";connectivity=1
Accept: application/pidf+xml
Content-Length: 0
2013-08-07T14:24:20+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:20,951" Module="network.sip" Level="INFO":  Dst-ip="82.132.234.165"  Dst-port="39014"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@company.co.uk, Call-ID=031ac5ef110a3919@127.0.0.1"
2013-08-07T14:24:20+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:20,951" Module="network.sip" Level="DEBUG":  Dst-ip="82.132.234.165"  Dst-port="39014"
SIPMSG:
|SIP/2.0 404 Not Found
Via: SIP/2.0/TLS 10.5.161.68:54616;branch=z9hG4bKb90dd0448af3919e2bf7b557b3e264e4.1;received=82.132.234.165;rport=39014;ingress-zone=DefaultZone
CSeq: 201 SUBSCRIBE
To: <sip:provisioning@company.co.uk>;tag=ac4e538d118e31a0
Server: TANDBERG/4120 (X7.2.1)
Warning: 399 192.168.10.10:5061 "Policy Response"
Content-Length: 0
2013-08-07T14:24:21+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:21,125" Module="network.tcp" Level="DEBUG":  Src-ip="82.132.234.165" Src-port="39014" Dst-ip="192.168.10.10" Dst-port="5061" Detail="TCP Connection Closed"
2013-08-07T14:24:34+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:34,501" Module="network.h323" Level="INFO":  Src-ip="10.10.1.70"  Src-port="1719"
  Detail="Received RAS NST  SeqNum=22573  ASSENT Probe"
2013-08-07T14:24:34+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:34,501" Module="network.h323" Level="DEBUG":  Src-ip="10.10.1.70"  Src-port="1719"
Received RAS PDU:
value RasMessage ::= nonStandardMessage :
   requestSeqNum 22573,
   nonStandardData
     nonStandardIdentifier h221NonStandard :
       t35CountryCode 130,
       t35Extension 1,
       manufacturerCode 256
     data '03000004'H
   genericData
       id nonStandard : 'C2F2D2A2152711DDA1230FC456D89593'H,
       parameters
           content raw : '3C7265736F757263657573616765696E666F3E3C74726176657273616C63616C6C7361 ...'H
2013-08-07T14:24:34+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:34,501" Module="network.h323" Level="INFO":  Dst-ip="10.10.1.70"  Dst-port="1719"
  Detail="Sending RAS NST  SeqNum=22573  ASSENT Probe"
2013-08-07T14:24:34+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:34,501" Module="network.h323" Level="DEBUG":  Dst-ip="10.10.1.70"  Dst-port="1719"
Sending RAS PDU:
   nonStandardData
       t35CountryCode 130,
       t35Extension 1,
     data '03000004'H
   genericData
       parameters
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,911" Module="network.sip" Level="INFO":  Src-ip="10.10.1.70"  Src-port="25596"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:192.168.10.10:7001;transport=tcp, Call-ID=af8dcd4f7959defa@10.10.1.70"
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,912" Module="network.sip" Level="DEBUG":  Src-ip="10.10.1.70"  Src-port="25596"
SIPMSG:
|OPTIONS sip:192.168.10.10:7001;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 10.10.1.70:5060;branch=z9hG4bK5380daf2a89606ecf38ba965c659b393156967;received=10.10.1.70;rport=25596
Call-ID: af8dcd4f7959defa@10.10.1.70
CSeq: 57054 OPTIONS
To: <sip:192.168.10.10:7001>
Max-Forwards: 0
User-Agent: TANDBERG/4120 (X7.2.1)
Supported: com.tandberg.vcs.resourceusage
Content-Type: text/xml
Content-Length: 250
<resourceusageinfo><traversalcallsavailable>250</traversalcallsavailable><nontraversalcallsavailable>750</nontraversalcallsavailable><registrationsavailable>2492</registrationsavailable><turnrelaysavailable>0</turnrelaysavailable></resourceusageinfo>|
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,912" Module="network.sip" Level="INFO":  Dst-ip="10.10.1.70"  Dst-port="25596"   Detail="Sending Response Code=401, Method=OPTIONS, To=sip:192.168.10.10:7001, Call-ID=af8dcd4f7959defa@10.10.1.70"
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,912" Module="network.sip" Level="DEBUG":  Dst-ip="10.10.1.70"  Dst-port="25596"
SIPMSG:
|SIP/2.0 401 Unauthorised
CSeq: 57054 OPTIONS
To: <sip:192.168.10.10:7001>;tag=f930caa190c2a48b
WWW-Authenticate: Digest realm="TraversalZone", nonce="feba5014f914c7743ace26e95b2ed4214410a1116851e6125ba93c836de2", opaque="AQAAAJEZC9EK4+dBfO64t+LS/P173VZ7", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,914" Module="network.sip" Level="INFO":  Src-ip="10.10.1.70"  Src-port="25596"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:192.168.10.10:7001;transport=tcp, Call-ID=af8dcd4f7959defa@10.10.1.70"
2013-08-07T14:24:37+01:00 example-vcse tvcs: UTCTime="2013-08-07 13:24:37,914" Module="network.sip" Level="DEBUG":  Src-ip="10.10.1.70"  Src-port="25596"
SIPMSG:
Via: SIP/2.0/TCP 10.10.1.70:5060;branch=z9hG4bK2c6b4eb262bcae2e8b888fc0e7b918ab156968;received=10.10.1.70;rport=25596
CSeq: 57055 OPTIONS
Max-Forwards: 0
Authorization: Digest nonce="feba5014f914c7743ace26e95b2ed4214410a1116851e6125ba93c836de2", realm="TraversalZone", opaque="AQAAAJEZC9EK4+dBfO64t+LS/P173VZ7", algorithm=MD5, uri="sip:192.168.10.10:7001;transport=tcp", username="admin", response="2658c3d3bbf7d48840e5ec32de3f20e9", qop=auth, cnonce="2aac9373e769726b6081804648fb9451f601dbbb9c4de38ab124c5a2ee0b", nc=00000001
Content-Length: 250
2013-08-07T14:24:37+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:37,915" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:9998/credential/name/admin" Ref="0x4f7dc60"
2013-08-07T14:24:37+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:37,917" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="9998" Dst-ip="127.0.0.1" Dst-port="48225" Response="200 OK" ResponseTime="0.002104" Ref="0x4f7dc60"
2013-08-07T14:24:37+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:37,917" Module="network.ldap" Level="INFO":   Detail="Authentication credential found in directory for identity: admin"
2013-08-07T14:24:37+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:37,918" Module="network.sip" Level="INFO":  Dst-ip="10.10.1.70"  Dst-port="25596"   Detail="Sending Response Code=200, Method=OPTIONS, To=sip:192.168.10.10:7001, Call-ID=af8dcd4f7959defa@10.10.1.70"
2013-08-07T14:24:37+01:00 vdot-vcse tvcs: UTCTime="2013-08-07 13:24:37,918" Module="network.sip" Level="DEBUG":  Dst-ip="10.10.1.70"  Dst-port="25596"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 57055 OPTIONS
To: <sip:192.168.10.10:7001>;tag=84b7be29d1c57166
Supported: com.tandberg.vcs.resourceusage,path,outbound,gruu
Content-Length: 253
Hi Daniel,
the response to initial subscribe message is a 404 not found by expressway.
SIPMSG:
CSeq: 201 SUBSCRIBE
From: <>username@company.co.uk>;tag=2c7a45453c26f945
To: <>provisioning@company.co.uk>;tag=ac4e538d118e31a0
Content-Length: 0
do you have a device provisioning key on the expressway?
- if yes, can you delete the device provisioning ke and reboot the expressway server and check again and let us know.
Rgds
Alok
Thanks Alok.
Yes there was a device provisioning key on the expressway so i deleted it, rebooted and created a log again.
See below:
Module="network.tcp" Level="DEBUG":  Src-ip="82.132.238.203" Src-port="14453" Dst-ip="192.168.10.10" Dst-port="5061" Detail="TCP Connecting"
2013-08-23T09:43:33+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:33,440" Module="network.tcp" Level="DEBUG":  Src-ip="82.132.238.203" Src-port="14453" Dst-ip="192.168.10.10" Dst-port="5061" Detail="TCP Connection Established"
2013-08-23T09:43:34+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:34,391" Module="network.sip" Level="INFO":  Src-ip="82.132.238.203"  Src-port="14453"   Detail="Receive Request Method=SUBSCRIBE, Request-URI=sip:user@company.co.uk, Call-ID=067792a99961c9ac@127.0.0.1"
2013-08-23T09:43:34+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:34,391" Module="network.sip" Level="DEBUG":  Src-ip="82.132.238.203"  Src-port="14453"
SIPMSG:
|SUBSCRIBE sip:user@company.co.uk SIP/2.0
Via: SIP/2.0/TLS 10.86.172.38:63574;branch=z9hG4bK903ff4692dfe38138afbaad34d190d4f.1;received=82.132.238.203;rport=14453
Call-ID: 067792a99961c9ac@127.0.0.1
CSeq: 401 SUBSCRIBE
Contact:
Max-Forwards: 70
Route: <62.232.111.119:5061>
Expires: 300
Content-Length: 0
2013-08-23T09:43:34+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:34,393" Module="network.sip" Level="INFO":  Dst-ip="82.132.238.203"  Dst-port="14453"   Detail="Sending Response Code=404, Method=SUBSCRIBE, To=sip:provisioning@company.co.uk, Call-ID=067792a99961c9ac@127.0.0.1"
2013-08-23T09:43:34+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:34,393" Module="network.sip" Level="DEBUG":  Dst-ip="82.132.238.203"  Dst-port="14453"
SIPMSG:
Via: SIP/2.0/TLS 10.86.172.38:63574;branch=z9hG4bK903ff4692dfe38138afbaad34d190d4f.1;received=82.132.238.203;rport=14453;ingress-zone=DefaultZone
CSeq: 401 SUBSCRIBE
To: <>provisioning@company.co.uk>;tag=b9f0520ef1275ce7
Content-Length: 0
2013-08-23T09:43:34+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:34,559" Module="network.tcp" Level="DEBUG":  Src-ip="82.132.238.203" Src-port="14453" Dst-ip="192.168.10.10" Dst-port="5061" Detail="TCP Connection Closed"
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,117" Module="network.sip" Level="INFO":  Src-ip="10.10.1.70"  Src-port="26542"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:192.168.10.10:7001;transport=tcp, Call-ID=36c96db63d3b42b0@10.10.1.70"
2013-08-23T09:43:38+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:38,118" Module="network.sip" Level="DEBUG":  Src-ip="10.10.1.70"  Src-port="26542"
SIPMSG:
Via: SIP/2.0/TCP 10.10.1.70:5060;branch=z9hG4bK16dd0968b715a30f8c55713c807357dc325019;received=10.10.1.70;rport=26542
Call-ID: 36c96db63d3b42b0@10.10.1.70
CSeq: 53437 OPTIONS
To: <192.168.10.10:7001>
Max-Forwards: 0
Content-Length: 250
25075024920|
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,118" Module="network.sip" Level="INFO":  Dst-ip="10.10.1.70"  Dst-port="26542"   Detail="Sending Response Code=401, Method=OPTIONS, To=sip:192.168.10.10:7001, Call-ID=36c96db63d3b42b0@10.10.1.70"
2013-08-23T09:43:38+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:38,118" Module="network.sip" Level="DEBUG":  Dst-ip="10.10.1.70"  Dst-port="26542"
SIPMSG:
CSeq: 53437 OPTIONS
To: <192.168.10.10:7001>;tag=257e23d5cd1864a0
WWW-Authenticate: Digest realm="TraversalZone", nonce="0f1936bcd3c4c58b86d27e88a7178d43c0c8a2e34c5b6afe88e779d0be5b", opaque="AQAAAHHRU8cD8y+XxpFAF9j93sa6Vrns", stale=FALSE, algorithm=MD5, qop="auth"
Content-Length: 0
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,119" Module="network.sip" Level="INFO":  Src-ip="10.10.1.70"  Src-port="26542"   Detail="Receive Request Method=OPTIONS, Request-URI=sip:192.168.10.10:7001;transport=tcp, Call-ID=36c96db63d3b42b0@10.10.1.70"
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,119" Module="network.sip" Level="DEBUG":  Src-ip="10.10.1.70"  Src-port="26542"
SIPMSG:
Via: SIP/2.0/TCP 10.10.1.70:5060;branch=z9hG4bKbe71a5d177af210e973b8f490f2e9f36325020;received=10.10.1.70;rport=26542
CSeq: 53438 OPTIONS
Max-Forwards: 0
Authorization: Digest nonce="0f1936bcd3c4c58b86d27e88a7178d43c0c8a2e34c5b6afe88e779d0be5b", realm="TraversalZone", opaque="AQAAAHHRU8cD8y+XxpFAF9j93sa6Vrns", algorithm=MD5, uri="sip:192.168.10.10:7001;transport=tcp", username="admin", response="fc47aac5c0320dbad26cb6d43a6758fc", qop=auth, cnonce="d8603e834a51f9136ed7b542dc3a1ed704e28c36d8fff6dfb4da8d64190c", nc=00000001
Content-Length: 250
25075024920|
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,120" Module="network.http" Level="DEBUG":  Message="Request" Method="POST" URL="http://127.0.0.1:9998/credential/name/admin" Ref="0x7f1a3c230610"
2013-08-23T09:43:38+01:00 expressway tvcs: UTCTime="2013-08-23 08:43:38,122" Module="network.http" Level="DEBUG":  Message="Response" Src-ip="127.0.0.1" Src-port="9998" Dst-ip="127.0.0.1" Dst-port="45324" Response="200 OK" ResponseTime="0.002064" Ref="0x7f1a3c230610"
2013-08-23T09:43:38+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:38,122" Module="network.ldap" Level="INFO":   Detail="Authentication credential found in directory for identity: admin"
2013-08-23T09:43:38+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:38,122" Module="network.sip" Level="INFO":  Dst-ip="10.10.1.70"  Dst-port="26542"   Detail="Sending Response Code=200, Method=OPTIONS, To=sip:192.168.10.10:7001, Call-ID=36c96db63d3b42b0@10.10.1.70"
2013-08-23T09:43:38+01:00 vdot-vcse tvcs: UTCTime="2013-08-23 08:43:38,122" Module="network.sip" Level="DEBUG":  Dst-ip="10.10.1.70"  Dst-port="26542"
SIPMSG:
|SIP/2.0 200 OK
CSeq: 53438 OPTIONS
To: <192.168.10.10:7001>;tag=4b12e3f894cbea8a
Content-Length: 253
Thanks!
1047
