Jabber connection without vpn
how to connect Jabber to the CUCM through internet using ASA without VPN
I don't have expressway
Is there embedded vpn inside jabber like vpn phone ?
I suppose you could set up
I suppose you could set up port forwarding or something similar. I would suggest looking into Collaboration Edge as it will be the most secure.
 I'm in a new projectHow to
How to get the expressway edge and expressway core software with the initial license ?
If you need the software and
If you need the software and license you should contact your Cisco Partner or Cisco SE. They will be able to direct you on how to order and download.
159
