Jabber Deployment Custome MSI with ORCA
I am getting the error below when I try to edit MSI manually or with CiscoJabberProerties.mst using MS ORCA.
"This MSI contains at least one embedded substorage which cannot be copied to the new package. You will need to manually import these substorages into the new file."
I have Jabber 9.2
Windows 7 Pro 64 Bit OS
Microsoft ORCA
Microsoft Visual Express 2010 SP 1
Please suggest if any one have similar issue and resolved the same.
Amritesh Anand
1 REPLY
you can ignore this error. i believe its a defect in the Orca tool.
485
