Community Member
Jabber Desktop Toolbar
Is it possible disable Jabber toolbar on desktop?
1 ACCEPTED SOLUTION
Re: Jabber Desktop Toolbar
Jabber 9.2 for windows?
Yes, under view menu and uncheck show docked window. There is a setting in the jabber-config.xml file to for it.
Community Member
Thanks. I had missed out this option))
464
