Jabber for Andriod No Outgoing
HI All,
I have just deploid the latest Jabber Android client on CUCM 8.6 and cannot make outgoing calls from the Mobile phone. Here is what I have done.
Created the Android extension on CUCM 8.6 ( Status - Registered)
Associated End User (Super user with all rights)
Associated the Jabber extension with a Primary deskphone associated to the End User.
Associated the End user to the Line.
Added the Device under Controlled Devices.
Now I am able to recieve Incoming calls coming to my Deskphone on the Smartphone. But cannot make outgoing calls. Error - Server Error.
Attached is the log from CUCM.
Can anyone please help me with the right configuration checklist.
Thanks in Advance
Abraham
Hi Abraham,
Please provide the called number from the jabber for outgoing  call and the time stamp.
Also, provide the jabber version as well.
Re: Jabber for Andriod No Outgoing
Thank you so much for the reply Hanson. I badly need some help. I have a customer presentation tomorrow and this is their primary requirement. I have no clue. Below are the details.
Jabber Client Registered as : BOTABRAHAM
Calling Number : 4010
Called Number : 4030
I have no Application Dial Rules since this is just an internal call.
The log file is from the Real Time Trace so there is no specific time stamp as such since the entire log is from the single call attempt I made.
I am attaching the SDI Log file as well.
Abraham
Jabber Version is 8.6.1.842
I was able to solve this.. There was no additional steps required. The device I was using was not compatible. This works fine on a Samsung Galaxy
1093
