Jabber for Android 9.6 - Users can´t call directly to users in their Contact List
Hi Guys, My Cisco Jabber for Android (9.6) is working very well with all solutions integrated (UCM, CUPS, UNITY), but I´m confused with one thing.
Im my contact List I see the "phone icon" on the right of the contact, but my problem is: When I Try to call to this contact I receive the error this contact not have a number.
When I search the same contact in "Search field" I can call this contact normally (Yellow Arrow).
So.... What I need to do to this icon on the right of the contact (first Image) be enabled?
Leonardo Oliveira www.avvid.net "Scientia potentia est"
1 ACCEPTED SOLUTION
Wild guess, you failed to
Wild guess, you failed to configure properly contact resolution, so, Jabber for Android cannot reach the directory source, from where it pulls the DN to dial.
I'm almost certain that's your issue, as the 2nd screen clearly shows a @ in the name, meaning it's failing to change your email ID to your name.
java
if this helps, please rate
www.cisco.com/go/pdi
java
Hi Jaime, thanks for
Hi Jaime, thanks for clarifying this for me.
I think you're right, I checked and jabber-config.xml does not seem to be configured correctly. I'll do some tests using the Jabber Config File Generator and update here with the results.
See ya
Community Member
Hi, Have you been able to
Have you been able to resolve this issue. We are seeing the same problem within our environment as well.
Ned
Hi, as recommended by Jaime
Hi, as recommended by Jaime (Thx man!), I did the customization of the jabber-config.xml in my enviroment.
After that the Photos began to appear in mobile devices (Android, iPad and Iphone)
Below is my config. Copy, edit, save, upload to TFTP, restart the TFTP´s, re-log in you mobile device aaaaaand Enjoy.
<?xml version="1.0" encoding="utf-8"?>
<config version="1.0">
<Options>
<StartCallWithVideo>false</StartCallWithVideo>
<ShowOfflineContacts>false</ShowOfflineContacts>
</Options>
<Presence>
<PresenceServerAddress>IPADD</PresenceServerAddress>
</Presence>
<Directory>
<DirectoryServerType>BDI</DirectoryServerType>
<BDIPhotoSource>jpegPhoto</BDIPhotoSource>
<BDILDAPServerType>AD</BDILDAPServerType>
<BDIPrimaryServerName>IP-AD-1</BDIPrimaryServerName>
<BDIPresenceDomain>example.com</BDIPresenceDomain>
<BDIServerPort1>389</BDIServerPort1>
<BDISecondaryServerName>IP-AD-2</BDISecondaryServerName>
<BDIServerPort2>389</BDIServerPort2>
<BDIConnectionUsername>USER</BDIConnectionUsername>
<BDIConnectionPassword>PASS</BDIConnectionPassword>
<BDISearchBase1>ou=root,dc=example,dc=com</BDISearchBase1>
<BDIUseANR>false</BDIUseANR>
<BDIBaseFilter>(&amp;(objectclass=user)(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))</BDIBaseFilter>
</Directory>
<Policies>
<Screen_Capture_Enabled>true</Screen_Capture_Enabled>
<File_Transfer_Enabled>true</File_Transfer_Enabled>
<Disallowed_File_Transfer_Types>.msi;.rar;.zip;.mp3</Disallowed_File_Transfer_Types>
<Video_Disabled>false</Video_Disabled>
</Policies>
<CUCM>
<PhoneService_UseCredentialsFrom>presence</PhoneService_UseCredentialsFrom>
</CUCM>
</config>
Ref: http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/jabber/Android/9_6/JABA_BK_J0A7146D_00_jabber-android-install-config-9-6/JABA_BK_J0A7146D_00_jabber-android-install-config-9-6_chapter_0110.html#CJAB_RF_C292501F_00
Community Member
Thanks man!!! Both of you!
341
