Jabber for Android shows up with CUWL License
i got a strange issue on a Cisco Callmanager 9.1.2.10000-28. When i add a new device "Cisco Dual Mode for Android" as single Device, it shows up in the license usage as CUWL Standard. I think this is wrong. Every iPhone device is showing up with Enhanced Plus license. Only the Android devices will show up with the wrong license type.
Has anyone seen this?
The problem is, that the customer bought the license for Enhanced Plus (what should enough)...
Thanks for any suggestions...
Christian
Re: Jabber for Android shows up with CUWL License
I got the same problem. Did you receive an explanation from Cisco TAC?
Wouter
does anyone of you has a solution to this problem. I'v got the same problem at a customer site.
Martin
Hey Guys,
i think this will be a bug in the Callmanager Software. In the next 2 weeks i will update the customer system and then i can say more about the issue.
Christian
Was having this issue also, recently upgrade to version 9.1.2.11900-12. And i jabber for android is correctly consuming an enhanced+
1400
