Jabber for android with anyconnect
Hi ,
I cannot seem to get jabber registered when using Any conneCT. I can make it work with
with blizzard however it doesn't work on vpn.
Sent from Cisco Technical Support Android App
1 REPLY
Since you can register fine over WiFi, it sounds like a problem using the VPN.  In which case, since you're a Cisco Employee, you may want to open a Cisco IT ticket to have them investigate the ASA when you attempt to register using AnyConnect.
442
