Jabber for Everyone
Hello, I just want to ask about the Jabber for Everyone. I have been searching on how to configure it but apparently I could not find a resource for it. I only know that it uses the same installer as the Jabber for Windows or Jabber for Android. If that is the case, I was wondering how does it differ in configuration? Hope someone can help.
Thank you.
1 ACCEPTED SOLUTION
Yes, remove all the voice
Yes, remove all the voice endpoints you created in CUCM for Jabber, to leave only IM and presence as features available..
java
if this helps, please rate
www.cisco.com/go/pdi
Jabber for everyone is just a
Jabber for everyone is just a term, it means you can only configure IM and presence with the Jabber clients without a license. No voice capabilities. That's it. If you want to go full UC, then you need licenses.
java
Hello Jaime,I have already
Hello Jaime,
I have already deployed Jabber for Windows and Android. And they all have voice and video capabilities and also use-up licenses. How do I configure it in such a way that it will only be used for IM and does not use-up a license?
Remove all the voice config
Remove all the voice config from CUCM, all the devices you configured there.
java
What do you mean? Remove the
What do you mean? Remove the CSF devices?
java
Thanks Jaime! So for all of
Thanks Jaime! So for all of you guys, what I did was you don't have to create CSF, BOT, TCT devices for those users who will use Jabber for Everyone or "Jabber IM Only". You just have to enable the IMP for those users under User Management. That's it!
Just curious how desk phone
Just curious how desk phone control through CTI works?  This is still included with Jabber for Everyone licensing, correct?
Aaron
Jabber for everyone is ONLY
Jabber for everyone is ONLY IM and Presence capabilities.
java
161
